CCleaner not starting
Okay so after some googling, quick search through forums here and there and i have yet to find a solution to why i can't get CCleaner to run at all. Installer works fine, uninstaller aswell, but for some reason when i try to run the app itself nothing happends. It doesn't appear in Task Manager, it doesn't give any errors, just plain nothing.
Running on Windows 10 Pro, 64bit with Avast free antivirus, tried disabling it, tried to run both x32 and x64 with and without admin rights, different compatibility modes and pretty much everything i could think of :/
Does CCleaner run if you boot into Windows Safe Mode?
Tried, but nope
How are you trying to launch CCleaner, Desktop icon?, Taskbar icon?, other?
And is it in the standard directory? (C:\Program Files\CCleaner\)
It sounds as if the shortcut linked to the icon may be pointing to the wrong thing.
(Unless it's actually opening and closing immediately for some reason, or something else is blocking it)
What happens if you navigate to it's location in File Explorer and double click on CCleaner64.exe (or CCleaner.exe) ?
To me this sounds as if you "may have an old version" installed, and Windows 10 if you use that OS won't allow you to use some old versions of CCleaner.
Tried straight from the default folder, both just double click CCleaner64.exe and r-click run as admin, which pops the are you sure you want to run as admin but after that nothing.
And the version is the latest i got from here, as far as i know there is no other versions installed, guess i should go throu registery manually and remove every mention of CCleaner
Try seeing if the Slim Build from here will run.
https://www.ccleaner.com/ccleaner/builds
Holy Hazelnuts, that actually works. I tried the one without installer, but for some reason i've never tried this Slim version. Finally. Thank you!
Holy Hazelnuts ???? :lol:
Glad to hear you are up and running again !
Holy Batmanquotes or something, it was the first that popped in my mind, no offense.
I've been trying to get this up and running several times now, wonder why i have never tried that slim before...
More to the point I wonder why the slim worked and not the standard?
Once installed the .exe files are supposed to be identical.
(It's only the bundles/offers in the standard installer that are supposed to be different).
Maybe your AV was blocking the Standard installer because of the bundles and so it wasn't installing the main programme properly?
Then as there is no bundle in the slim your AV let it through?
Only guessing.
But then again shouldn't the one with no installer work fine?
I could try turning Avast off and running the installer once more, now that it seems the slim works.
Can you show me a screenshot of the installed directory?
Nicon not much there, CCleaner and 64 executables, CCUpdate, uninst, Lang and Setup folders. Don't think i had setup folder before, thou it's empty. Also license .txt missing
That shouldn't make a difference.
I ony have CCleaner64.exe and uninst.exe. - Because I deliberately deleted all the rest as not needed/unwanted. (especially CCUpdate.exe).
CCleaner runs fine on my machine with just the one executable present.
There must have been something odd about the exe you originally had.
Or maybe the registry entries hadn't installed properly last time and installing the slim corrected them?
Turning off an AV is not the same as uninstalling it.
The only way to truely test is to uninstall Avast and try the full installer again.
As Avast owns CCleaner some might think it strange that a block could happen ...I don't.
