cCleaner "not responding"
Hello,
I have installed cCleaner on my computer and I can run the "Analyze" function just fine. But, when I try to use the clean function, or "remove" my cCleaner stalls and it eventually gives me a message that says, "cCleaner not responding." What can I do to solve this problem? Any help is hugely appreciated.
Thanks,
willie
Possibly "you may have so many junk files on your system causing it". You could uncheck some of the cleaning options and run them individually. That's just one possibility.
