CCleaner 7.9.1432.0 is not recognizing the current installed Microsoft Cumulative Update for Windows 10 Version 22H2 for x64-based Systems (KB5099539) and keeps trying to update it when it has already been installed.
Hi @hoggie,
Please send me a screenshot showing the update in Windows and the offered update in CCleaner.
Please also follow these steps to help us investigate the issue:
- Download and install the CCleaner Support Tool using the link below: https://download.ccleaner.com/CCleanerSupportTool.exe
- Replicate the issue on your end.
- Run the tool to generate the logs.
- At the end of the process, you’ll receive a 5-digit File ID.
Laurence, the file ID is 4DOS0
I have also attached a screen shot of the windows update history and Ccleaner app update screen
Mike
Laurence,
I believe you can cancel this issue. Windows did another update last night on my PC related to the cumulative update and Ccleaner now shows everything is up to date.
Checked my windows 10 update history and found that cumulative update with a new install date.
Was 7-16-26 now 7-18j-18
I suspect them needed to amend the update.
Thanks,
Mike
Thanks for this update Mike, I am glad to hear this issue has been resolved.
If you experience it again, please message me back so we can investigate this further.
