I just installed CCleaner on my daughters computer and it is not in the Menu list of all programs. I click Start > All Programs and cannot find it. However, it is in add/remove and is located on the C drive. Since I did not choose to install a desktop Icon, I just added a shortcut using the icon in the CCleaner folder from its folder on the C drive. How do I add the program to my programs list? Also, does this mean I did not have a clean install and should uninstall and reinstall again. Seems to work fine. Any help would be appreciated.
I uninstalled and during the last reinstall I noticed that their is an option to add a shortcut to the desk top and below this is the option to add a shortcut to the programs. This second one is a check box that I unchecked on install. Is this the reason that it did not show in the all programs list. Is that what the second checkbox is for??
Second question, I noticed that when I run CCleaner it changes the homepage on IE I had replaced the original with. Why is this. Is their a way for CCleaner to leave the homepage I want in IE as is?
Thanks, any further help with these two questions would be appreciated.
That would be why you don't have it in the Start Menu.
I was improperly selecting my default page in IE internet options. It had nothing to do with CCleaner. Took a while to figure out, but thanks for your response.
