Ccleaner not fixing registry
Hi as per usual I run Ccleaner several times a week. Well today I found 4 registry errors that Ccleaner can't fix.
Invalid file reference ImagePath - system32\mutex-threads.exe HKLM\SYSTEM\CurrentControlSet\services\.Net Crypt
Invalid file reference    ImagePath - system32\idle-threads.exe    HKLM\SYSTEM\CurrentControlSet\services\.Net Main
Invalid file reference    ImagePath - system32\latch-threads.exe    HKLM\SYSTEM\CurrentControlSet\services\.Net Security
Invalid file reference    ImagePath - system32\semaphore-threads.exe    HKLM\SYSTEM\CurrentControlSet\services\.Net Semaphore
When I tell Ccleaner to fix the issues I get the following message:
The file referenced at: HKLM\SYSTEM\CurrentControlSet\services\.Net Semaphore\ImagePath could not be located. These references are often left behind after uninstalling software.
Solution: Delete the registry key.
I've tried running Ccleaner numerous tirmes and even ran Malewarebytes to ensure it wasn't a virus. The scan revealed no maliscious activity.
Any idea what the solution is?
let's get the usual cautionary tales out of the way...
there's no reason to touch the registry. in fact, doing so, there's greater chance you'll make things worse.
official word from Microsoft is; <a href="https://support.microsoft.com/en-us/help/2563254/microsoft-support-policy-for-the-use-of-registry-cleaning-utilities" rel="external nofollow">https://support.microsoft.com/en-us/help/2563254/microsoft-support-policy-for-the-use-of-registry-cleaning-utilities</a>
if your PC is not popping up errors or these leftover registry keys causing issues, leave them alone.
now, for the fun stuff, since after all, it is a personal computer, and we all feel the need to fiddle...
you could right click on CC and Run as Administrator and see if that helps.
also try booting the PC into Safe Mode and trying from there.
or manually go into <strong>regedit</strong>, locate those hive keys and delete them yourself.
please, assume the worst and have a system image backup ready to use. B)
Well I tried the safe mode and the run as administrator options but they didn't seem to work. Could you give me a more detailed description on how to go about the regedit route?
20 hours ago, mta said:
		now, for the fun stuff, since after all, it is a <em>personal </em>computer, and we all feel the need to fiddle...
		please, assume the worst and have a system image backup ready to use.  <img alt="B)" data-emoticon="" src="<fileStore.core_Emoticons>/emoticons/default_cool.png" title="B)"></p>
Not sure if you get notifications if I just replied to your thread but not quoting so I thought I'd quote you in hopes you'd see it. I did try what you said except for the regedit part. Could you go into more detail about that? The other two things didn't work.
click Start, Run, type regedit and hit OK.
that'll start Regedit where you can locate those keys and delete them - but with all things registry related - if it ain't broke don't touch it.
having those unused entries will not hurt your PC.
If you're not familiar with RegEdit it's best left alone because if you start deleting the wrong things you can very easily make your PC non-bootable into Windows.
