easter
January 31, 2012, 2:17pm
1
Hi
On running Ccleaner over the past couple of weeks I am finding it is not reporting any problems in the Registry cleaner. Although this may seem a good thing I am concerned that the programme is faulty. (I have just installed the newest version and again, no problems showing at all).
I have been using CC for a long time and it has always found something to clean in the registry. Any help much appreciated. thanks
Can you please include your operating system info and service pack.
Also if you have another user on the pc and you run it in that account does the same thing happen?
Are you talking months here since ccleaner last found any reg entries?
Have you uninstalled anything lately (so you could see if it would list any reg entries for it)
What anti-virus do you use? Do you use any software which protects the registry?
easter
January 31, 2012, 4:32pm
3
Hi Hazelnut, thanks for replying
1. my system is XP with service pack 3
2. Only myself on this PC
3. Just the last couple of weeks no problems found
4. Have not uninstalled anything recently
5. I use MSE (Microsoft Security Essentials), Zone Alarm firewall, Malwarebytes, sorry, I don't know what software to protect the registry is !
Many thanks
It's normal for me to go weeks without seeing anything new on the list.
I'd say you're ok.
easter
January 31, 2012, 5:07pm
5
thanks for your reply Kroozer, I will go with that.
Many thanks
Easter
DennisD
January 31, 2012, 10:45pm
6
Completely off topic so apologies to Easter, but cool new avatar kroozer, and well done on hitting 1000 posts 3 posts ago. Remember them all?
Remember them all?
All the ones I wish to forget , and thanks for the kudos.
