CCleaner not emptying Recycle Bin
Hello, I have developed an issue with CCleaner. It is not emptying my Recycle Bin.
I have unistalled and reinstalled several versions including the latest and nothing helps..
All other file cleaning programs show it to be empty including Windows Disk Cleaner. Please advise, Thanks
Maybe this will help:
Sorry, I had already tried that before posting here and it didn't help. :(
Does it show anything in the recycle bin when you open it?
Do you have any other drives plugged in?
Are you the only user of the machine?
That's showing a lot of data for supposedly only 14 files?
I'd also suspect a corrupt bin but you say you've looked at that.
Try running the Windows Disk Cleanup and see if that corrects it. It may take a while to complete.
6 hours ago, nukecad said:
Maybe also run via an admin Command Prompt:
chkdsk /f C:
so many idiots posting above
go to options
go to advanced
uncheck "only delete files in the recycle bin older than 24 hours"
