Recently, CCleaner has not been displaying any restore points on my XP SP3 machine, despite Windows's own System Restore tool showing 4 restore points.
Turning System Restore off and back on has not helped, nor has uninstalling and reinstalling CCleaner.
You say you've reinstalled, but have you tried doing a complete removal, and then clean install of CCleaner?
You can back up all your settings by using the "Save settings to INI file" option in "Options\Advanced", and then go into the CCleaner folder, "C:\Program Files\CCleaner", and copy the "ccleaner.ini" file to a safe location to be copied back later into the new install.
You could use Revo Uninstaller to get all the registry entries if you're knowledge/experience has you comfortable with that.
Revo Uninstaller: (Free version download at the end of "Freeware" column, bottom of page.)
It seems to have been a problem with WMI, as System Information was unable to display any system information. One repair install later, and System Information and CCleaner are doing what they should.
I would appreciate more details on this solution ("One repair install later") as I too can't display any System Information. I used to be able to see and delete some restore points and love this feature of this excellent application...but now I have exactly the same problem as in this thread and have done an uninstall (using Revo) and clean install of Ccleaner but just can't see my restore points any more. So it looks like 'FortMax' has the solution.
It happened some weeks ago and I used to be able to see them. All I see now is the *briefest* start as if something is going to load... but then nothing. I'm running XP SP3 and yes I do have some restore points.
One note: if you have Internet Explorer 7 or 8, you'll need to either uninstall it before you do the repair installation, or reinstall it after.
Thank you so much for this prompt reply FortMax - I can see that it's more than a quick-fix so I'll do it when I've got time for a bit of space to devote to it - I'm a little bit into 'scary territory' here! Some more 'homework' to do I fear. Regards
EDIT (after more homework!):
Thanks to the tip-off from FortMax I have solved the problem of the System Restore points not showing up in Ccleaner AND of course my System Information Utility now works! Here's the link:
For the benefit of others, based on my problem, I can confirm, for my XP computer:
It is indeed a WMI problem and, as FortMax says (thanks Buddy), this is confirmed when you get an error when trying to see the contents of 'System Information Utility'. It all makes sense (well to me at least): if the System Information Utility isn't working then it won't 'report' System Restore points to Ccleaner.
There are lots of solutions floating around on the web but this one worked 100% for me:
a. Stop the WMI service (go to services.msc from the 'run' command)
b. Type this exactly in the run command "rundll32 wbemupgd, UpgradeRepository" (without the ""). It takes a few seconds to carry this out.
