CCleaner not deleting chrome history
The have already stated that the are working on a fix, I'm not sure where all the vitriol is coming from in this reply above me.
It feels a bit trolly when you type replies like those of @Question42. @billiam904, on the other hand, makes a good point, about you users having "done your jobs; without this community all coming together, to show that this bug wasn't the usual fixable issue (which @Question42 would have known if they had bothered to have read the thread) it may not have given the developers the information they needed to call it a bug. So a big hand to all of you who've replied civilly here, those of you should be proud of yourselves.
This is certainly NOT a new issue with CC. It's been an issue since I started using it. I've put up with it not for days or weeks but months, maybe years now, and finally decided that this just can't be acceptable for a paid service and a very popular browser. I tried their so-called fix which doesn't fix anything, eg, unclick the box that allows processes to run in the background, yet Piriform continues to display it as the fix! CC cleans away a little bit of IE dust in the corner but leaves a steaming pile of Chrome crap in the middle of the floor (3GB the last time!!, after I noticed videos were freezing up). Problem is that Piriform has known this for a long time. Again, this is not a recent problem with recent upgrades.
As I was looking through Chrome internal settings, perhaps there is a way to clean Chrome internally. I need to confirm it with a good CC cleaning, which unfortunately at the moment wipes all of Chrome off the GUI...have to re-initate all sites and pages. If I can do it internally within Chrome that would be a good thing, but then, of course, I would have NO need for CC. So this fix needs to be done NOW, or CC needs to tell us they can't, and those of us that use Chrome will simply unsubscribe. If this were a free service, sure, lots of slack given. But CC Pro is not some free service, meaning this fix shouldn't come from the goodness of their hearts, but from good business practices. This isn't "vitriol"...this is a disatisfied customer that wants to know that the fix is imminent, not be told to shut up and be patient we're working on it.
ok. this is getting ridiculous at this point. it has been about 3 weeks now since we first reported the issue and I was very supportive until now. Now, the issue is happening in the older version I installed. I bought this software specifically to clean my browser history AND IT DOESN'T WORK ANYMORE. As a software developer myself and a person who has managed software development teams, it is unacceptable to allow this type of bug to interfere with your customer's ability to use the software for this long. If I were managing this team and it took this long to fix a bug that directly affected the software's ability to function, someone would lose their job. If it doesn't get fixed soon, I will no longer do business with this company.
as you have the Pro version, have you raised a support ticket directly with Piriform?
I realize ccleaner does more than just wipe your browser history, but it is kind of ridiculous that it's been over 2 weeks and you guys haven't fixed it yet. Can't you just look at the changelog for 48.0.2564.109?
Chrome has updated yet again on the 18th Feb to stable build 48.0.2564.116.
On Feb 3rd it was stable build 48.0.2564.103
On Feb 9th it was stable build 48.0.2564.109
http://googlechromereleases.blogspot.co.uk/2016/02/stable-channel-update_18.html
I'm sure the ccleaner devs are tearing their hair out trying to get a fix out.
I would bet on Google intentionally changing something to thwart cleaning tools like CCleaner, etc., because it's just too much of a reoccurring issue as made evident when looking at old topics over the years.
I have the same problem since Chromium update. For fix the issue i have add "C:\Users\UserName\AppData\Local\Chromium\User Data\Default\History" file into CCleaner include file.
A screenshot of the CCleaner’s include menu:
I hope this could help somebody!
  • Windows 7 Professional (64-bit) + Service Pack 1
  • CCleaner 5.14.5493 (64-bit)
  • Chrome 48.0.2564.116 m (32-bit). Process completely closed and no sort of syncing enabled for history/bookmarks/etc..
CCleaner hasn't been clearing Google Chrome's history. As DrJones (thanks) suggested, I added the following file inclusion for Google Chrome under:
Options > Include > Add > File >
%LocalAppData%\Google\Chrome\User Data\Default\History
Google Chrome's history file is now properly cleared after running CCleaner.
Excellent solution DrJones & 0xEBFE. Thanks for sharing!
Hello, just FYI, updated to the latest version 20 minutes ago 5.15.5513 and chrome history is still not cleared. The fix might not be ready, but if it is it hasn't worked. If you're still working on it I'll shush and let you get on with it :)
Hello,
I wasn't sure if I should make a new thread as I have this same issue which for me has been resolved for Windows, but not for Mac.
I'm currently experiencing the same symptoms from this thread but for Mac. I'm also using the latest release to CCleaner for Mac v1.12.
Thanks.
@mmjr2000,
maybe the Mac threads would be a better place, if so, a Moderator will move it for you.
have you tried the INCLUDE solution (obviously changing to suit the Mac) offered above as a quick fix until a future version fixes the issue?
March 8th and still not fixed? Seriously? I use SRWare Iron (Chromium based Browser) I noticed after using ccleaner even after unchecking let apps run, That anything yahoo or google will automatically sign me in! This is unacceptable! A history Cleaner is supposed to clean history! It is not supposed to help keep easy to find login information for hackers and snoops! I hate being rude, But it seems all people do now is make excuses or guilt trip you, Or try to social engineer you to annoyance! It has been more than enough time to fix a simple issue! Unless you are taking money from google!
On that logic, one can conclude it is not a simple fix. As the flip-side of your argument is Piriform is leaving the bug in place on purpose just to..... what..... tick off its user base. I hardly think so.
But until such times as a solution is released, there seems to be a temporary fix that works.
It's been many months now. I just downloaded the latest CCleaner update, but Chrome History is still not being cleared out.
I've revisited this again and found something, although I don't know if it's the reason or not.
I wonder if this is the cause (taken from the cleaning routine in CCleaner v5.18.5607):
[Google Chrome - Internet History]
ID=2014
LangSecRef=3029
LangRef=3162
Section = Chrome
Default=True
SpecialDetect=DET_CHROME
SpecialKey1=N_CHROME_HISTORY
Notice the "Section = Chrome" part in the above cleaner, it's the only Google Chrome cleaner I found that has that in it, and usually when in the winapp2.ini file it would instead be "Section=Chrome" with no space in the naming.
It's weird for it to be in that built-in default cleaner since it already has a LangSecRef area which would mean there's no need for Section= since we use those to skip using LangSecRef when making a winapp2.ini cleaning routine.
I wonder if it could be causing the History to be skipped?
Hi TrytobeCleanGuy,
Can you please verify if you have your Chrome connect to a Google Account and History synchronization turned on. This will download your history back to your browser even after being cleaned by CCleaner.
On another note, we noticed the "Section" entry above and are removing it in the next release. But this is not causing any problems cleaning History. Thanks, Andavari for pointing it out.
Thanks
