CCleaner not deleting Chrome cookies [Fixed in CC5.89]
Laurence (Piriform Support)
				<span style="color:#bbbbbb;font-size:10pt;">Dec 21, 2021, 5:11 EST </span>
				<span style="color:#2b2e2f;font-size:10.5pt;">Hi Andy,
				I have been asked to look into your support request, sorry you are having problems with CCleaner cleaning your Chrome data.
				Thank you for highlighting this to us we have found the issue and it will be fixed in the next update to CCleaner.
				If you’re having any trouble with this, or if you need anything else, please feel free to email me back.</span>
				<span style="color:#2b2e2f;font-size:10.5pt;">Kind regards,</span>
				<span style="color:#2b2e2f;font-size:10.5pt;">Laurence | CCleaner Support - London, UK</span>
		</td>
	</tr></tbody></table>
It looks like Google Chrome has changed the location of the cookie. To clear cookies in google chrome, before clearing, you need to move the cookie file from the "User Data\Default\Network" folder to the "User Data\Default" folder. After clearing the cookie, you must return it back to "User Data\Default\Network"
4 minutes ago, zakoul said:
		There is no need to do that. CCleaner should take care of that if they make the update as they said they would. I have been deleting the network cookies using options include for months now with no problems.
Now we're programmers? Seriously, you need to stop shilling/defending Piriform.
The latest update for CCleaner still doesn't address the Chrome cookie issue. This is a great example of incompetence or ineptitude. Which one is it?
The WORKAROUND is to use Firefox or Edge (for W10+) or another Chromium based browser where it hasn't been moved the cookie location. Otherwise, use Chrome's Cookie cleaner Settings (Advanced mode) to clear all cookies, cookies within an hour, 24 hours, etc). Set up a bookmark: chrome://settings/clearBrowserData
Please note: Edge has the same issue with JS files as Chrome does. They build up indefinitely.
You need to add options, include to add the JS locations for both Edge and Chrome.
c:\Users\"USER"\
i think it all is nonsense, that there is no problem with the ccleaner program, where it allegedly is not deleting cookies.
also, i am not seeing any problems with the files at
"C:\Users\("user" )\AppData\Local\Google\Chrome\User Data\Default\Code Cache"
It is not nonsense. Yes, CCleaner is deleting the Default\Code Cache, but it is not deleting the new \Default\Network\Cookies nor all the JS files.
what you mean is that the ccleaner program is not deleting the file, which is named "cookies," in the "network" folder, and it is not deleting files within the "code cache" folder, but who says that that is a problem, that those files need to be deleted, other than you?
that is what i am saying, that i don't think that it actually is a problem that those files that you refer to are not being deleted. i am not seeing that they are a problem, on my computer.
@haapy, i did some testing and i see, now, what you are talking about, regarding the js-files, within chrome's "code cache\js" folder. they are not removed, automatically, by simple closing the chrome browser, or by simply running ccleaner. however, they are removed if you use chrome's own "clear browsing data."
that was why i wasn't seeing a problem, because i always run chrome's own "clear browsing data" before closing the chrome browser. (after having closed the browser, i then run "ccleaner," which removes some additional chrome-files that aren't removed when running chrome's own "clear browsing data" )
another thing is that, a few weeks ago, i switched from using the chrome browser to using the firefox browser. it's a long story but one of the reasons i switched to using the firefox browser was because, with the chrome browser, i was having too many issues with the "noscript" browser-extension, where it was blocking content, causing a problem. i have similar issues, using "noscript" with the firefox browser, too, but it is not as bad, with firefox.
the issue, with the cookies allegedly not being deleted, and with the js-files within chrome's "code cache\js"-folder, just came up in the last couple of weeks, after i had switched from using the chrome browser to using firefox, instead.
I have the same problem. How to fix it if the CCleaner cannot delete all cookies. I made a cleaner with cookies in Google Chrome selection, but when i open this Chrome>Settings, it still show the cookies
CCleaner version 5.88, Chrome version 96.0.4664.110, Windows 10 21H2
Thanks.
To recap, the latest Chromium version changed it's cookie storage location after the 5.88 build had already been completed. This is a known issue with Chromium-based browsers. CCleaner 5.89 will be updated to reflect this and then all shall be well with cookie cleaning once more.
Note that changes of this nature with browsers and other software that CCleaner cleans up after are fairly common - which is why we release so often, and why we always recommend using the latest version of CCleaner. Usually, we have our rules updated and a fresh version release before the browser changes take place, although in this case they beat us to it with our release timings disrupted around the Christmas/New Year period.
Be sure to have your automatic updates turned on so you get CCleaner 5.89 as soon as it comes out in the New Year.
thank you, dave. personally i am not noticing any issues with ccleaner's cookie-cleaning though it seems that some people are experiencing an issue, there.
there has been an ongoing issue with "safeframe.googlesyndication.com cookies," for some people. i am wondering if that is what people are seeing, "safeframe.googlesyndication.com" cookies? people aren't really giving the specifics of what it is that they are seeing when they say that chrome-cookies are not being deleted. but, again, i have not experienced the "safeframe.googlesyndication.com"-cookies-problem, either.
it has been said that the "safeframe.googlesyndication.com cookies" are just some type of "placeholder" for ads that appear on webpages. also, it has been said that they orginate from "tpc.googlesyndication.com" ("TPC" stands for "third-party-cookie" ), so i have "tpc.googlesyndication.com" blocked in my HOSTS file, and in my own custom blocklist for the "ublock origin" browser-extension, and in my browsers' cookie-settings, too.
https://www.google.com/search?q=safeframe.googlesyndication.com+cookies
incidentally, i use the "cookie autodelete" browser-extension. it's possible that that has some bearing on why i am not seeing any problem with cookies not being deleted. i also have my browsers set to block third-party cookies.
to add, i am not seeing an issue with the "cookies" file within chrome's new "network" folder, at "C:\Users\(user)\AppData\Local\Google\Chrome\User Data\Default\Network." when i open the file, the only data, there, that i see, is for the few cookies that i have "saved."
i created a custom-rule for ccleaner to remove files at chrome's "C:\Users\(user)\AppData\Local\Google\Chrome\User Data\Default\Code Cache\js" while saving the "index" file, there. (those files also can be removed by running chrome's own "clear browsing data" )
the same rules for the edge-chromium browser..
Dave, does CCleaner have any plans to offer an option to delete the Chrome and Edge JS files? Thanks. Andy
This is a great example of a troll-like comment. We see this kind of mindset with anti-vaxxers, covidiots, and conspiracy theorists (just to name a few). If they [personally] don't experience a behaviour or outcome, then they blatantly deny there's an issue or concern.
I am glad Dave, the Admin finally acknowledged the issue so trolls like redwolfe can reflect on their twisted thinking.
		Note that changes of this nature with browsers and other software that CCleaner cleans up after are fairly common - which is why we release so often, and why we always recommend using the latest version of CCleaner.  Usually, we have our rules updated and a fresh version release <strong>before </strong>the browser changes take place, although in this case they beat us to it with our release timings disrupted around the Christmas/New Year period.
*bump*
When is the update going to be rolled out?
Hello
Any news when will be new version of CCleaner PRO with Windows 11 Microsoft Edge 97.0.1072.55 support?
Best Regards
TaKeN
Hi everyone. We do not currently have a definitive estimation as to when the new version of CCleaner (v5.89) will be released as it depends on several various factors but I strongly suspect this will happen before the end of next week, at which time the cookie cleaning issue should be corrected.
Let's hope so. Because many websites are optimized for Chromium browsers such as Edge,
Having to manually delete certain cookes and keep only the ones you want is a PIA. Although I have now set Firefox as my default browser (for most sites). Someone should create a browser extension that has this capablity.
If you want to save cookies in Chrome, in CCleaner go to Options, Cookies and move the cookies you want to keep into the Cookies to Keep column. The cookies are always saved when you do a custom clean.
This is a simple one time thing to do unless you want to keep additional cookies down the road.
For me, I have a huge list of cookies I want to keep—from financial institutions and government websites. That's why I became so reliant on CCleaner, but now it's just the "old-fashioned way" of deleting cookies one by one, launching Chrome in Incognito, use Firefox, or using Chrome's nuclear approach.
Anyway, it's Thursday night. Almost the end of the week. Let's see if there'll be an update tomorrow or this weekend. I'm not holding my breath, though.
