CCleaner Not Cleaning
I reported this to the bug section, since I have things properly setup, and there is no reason for this not to clean, and I considered it possibly a bug, and reported it to the Bug section, unless someone has a possible solution for getting this to work.
See the link here:
http://forum.piriform.com/index.php?showtopic=9601
THANKS
Look at this post with a screenshot to see if you haven't enabled
Cleaner->Advanced->Custom Files and Folders
AH HA, so that's the problem, let me bang my head a few times, LOL. :blink:
THANKS
