Is there a reason why this is no longer working? I've used CCleaner ofr a while now but it's no longer cleaning chrome. It's skips chrome.
Hey Tiger,
Have you made sure to close your Chrome Browser before cleaning your device ? It can still run in the background if you don't close it from the tray section
3 minutes ago, Andrei CCleaner said:<div class="ipsQuote_contents"> <p> Hey Tiger, </p> <p> </p> <p> Have you made sure to close your Chrome Browser before cleaning your device ? It can still run in the background if you don't close it from the tray section </p> </div>
Browsers is always closed. I only noticed the problem a a few days ago. I googled the problem and I'm not the only one having this problem
You could try this:
https://community.ccleaner.com/topic/40285-ccleaner-not-deleting-google-chrome-history-fix/
37 minutes ago, Andavari said:<div class="ipsQuote_contents"> <p> You could try this:https://community.ccleaner.com/topic/40285-ccleaner-not-deleting-google-chrome-history-fix/
Thank you. That fixed it.
Good to know it works! I wasn't sure if it would or wouldn't work since that post is from 2014, and Google Chrome has had so many updates since then.
