CCleaner not cleaning all index.dat files
Wondering if others are seeing this problem. I ran CCleaner 1.39.502 with ALL Windows options ckecked, the CCleaner window after the run shows the current user cookies index.dat as marked for deleation. After a reboot I ran index.dat analyzer and under the Location drop down select cookies-current user. All the URL's are listed meaning current user cookies index.dat was not cleared. I ran Eraser 1.82 and the index.dat is clear after a reboot as viewed with index.dat analyzer. I uninstalled CCleaner 1.39.502 and installed 1.38.485. I then went back on line to let some the index.dat file be loaded with more stuff, ran CCleaner with ALL Windows options ckecked, again after runnng CCleaner shows the current user cookies index.dat as marked for deleation. But after another reboot index.dat analyzer still shows URL's in the current user cookies index.dat. The history-current user and cache-current user index.dat's are empty.
Running XP-PRO SP2 with all updates from Microsoft.
