CCleaner Newest Version Problems With Applications Removal
Since I downloaded the latest version of CCleaner 64Bit, I notice when I click the "Applications" tab and check for problems, a different number of problems shows up, even after just cleaning.
Also, each time I check for problems, it finds a low amount of problems but cleans more than it found and vice versa.
In other words, CCleaner should be finding problems and when I click to clean them, they should be gone. But with a second run looking for problems, more problems are found and either they arnt all cleaned or a higher or lower number of problems are cleaned??
Example- Found 24mg problems, cleaned 12mg. Found 67mg problems, cleaned 205mg problems.
No amount of times clicked looking for problems finds none! Even after cleaning 20 or more times!
Is anyone else experiencing this problem or noticed this happening?
What could be causing this?
>>>Note
CCleaner has never done this since I started using the program many years ago. I always update
to the latest version. Im running Windows 7-64bit and all programs are updated on my pc.
I have no problems with my pc at this time. I run antivirus and anti-malware daily, plus registry health checks for problems etc. I have limited programs in my start up and every possible check is done to keep my system stream lined and operating efficiently. Im an experienced pc user for over 20 years.
Have you tried a clean install of Ccleaner?
I presume you are getting CCleaner from Piriform or FileHippo? (sorry, have to ask!)
(Hope you don't do daily reg health checks)
Is it a specific type type seems to crop up? Like it's always chrome history and cache, or it's always ProgramX's temps; conversely it's always different things.
