CCleaner - multiple cleaning profiles
Hi all
I have set my cleaning choices using the checkboxes and CCleaner cleans my chosen areas - great.
Sometimes I just want to clean the temp folder, or browser cache but can't be bothered unchecking, cleaning and then re-checking all those checkboxes.
Would it be possible to save multiple checkbox choices as "profiles"?
For example, I could have a "Default" profile and a "Temp Folder" profile.
The checkbox choices would be different in each profile and I can select any profile from my list. Once I select a profile - CCleaner sets up the checkboxes as per the saved profile.
If this has been suggested before - apologies. If not - cool.
Blarty
It's never been suggested before, or at least I don't remember it. It's a very interesting concept to have cleaning profiles. :)
I have CCleaner configured to save settings to INI.
(I use the portable version but the installed version also does this)
I use several Desktop Short-cuts that each invoke the same BAT script, but with different "profile arguments".
The script copy replaces CCleaner.ini with a "template" selected by the profile argument,
and then runs CCleaner.ini.
For each template there is a once-off adjustment of CCleaner to do what is required,
and then CCleaner is closed to save settings to INI,
and then I rename the new INI with a new template name and compose a new Desktop short-cut
