CCleaner Monitoring
Windows 10(64bit) Lenovo laptop, CCleaner Ver 5.44.6575(64bit).
Under Options\Monitoring I don’t have the “Enable System Monitoring” box ticked and the Task Manager Startup programs shown no entries of CCleaner however when I check the System Information\Software Environment\Startup Programs CCleaner has 2 entries located in the registry.
I deleted the 2 registry entries but I don’t know if they will be re installed next time I start CCleaner.
Like many users I try to have the minimum programs loading at startup, so what CCleaner does is it a bug or it is normal?
