CCleaner Monitoring is Active Even Though Not Selected
I run CCleaner 4.18.4842 Free on Windows 8.1 x64.
I do NOT want system monitoring. See the attachment - system monitoring is NOT selected. But every time I run CCleaner, system monitoring is turned on and I have to manually turn it off. Worse, CCleaner adds a startup item for system monitoring - something else I didn't ask for.
How can I stop CCleaner from enabling system monitoring and adding system monitoring to Windows startup every time I run the program?
Please see here
http://forum.piriform.com/index.php?showtopic=41860
You have to uncheck two options: Enable System Monitoring and Enable Active Monitoring.
http://forum.piriform.com/index.php?showtopic=41858&p=253811
But there is also a new version available (4.18.4844).
http://forum.piriform.com/index.php?showtopic=41858&p=253778
Edit: hazelnut was faster. :)
Thanks to you both. :D
Enable system monitoring was unchecked, but Enable Active Monitoring was not unchecked. Ahhh...that's better!
