After running ccleaner the format of pages is completely messed up.
Firefox pages look different. The correction requires FF (tools/clear recent history) to restore the format, but I don't want to do this every time I run ccleaner.
Is there some adjustment that needs to be done on what ccleaner removes?
Did this occur with a previous version of CC as well ?
Untick every box. Then tick one by one a group of boxes and run CC. This is how you can narrow down which group cleans those settings. When you know which group is responsible then you can narrow it down even more by ticking one box at a time and run CC again.
Ccleaner totally disarranges my formats when used. Suggested cures don't work other than the required tools/delete recent history for FF every time ccleaner is used. Decided to uninstall ccleaner. Thanks for the responses.
