I installed Ccleaner and ran it. After I did that, now I can only receice emails in my Outlook but cannot send. Plus I cannot log in my Net bank anymore! I wished I had never ran Ccleaner on my pc. I tried erasing my account in my Outlook and start a new account but it doesn't help.
Im afraid I don't use Outlook I use Outlook Express and its never stopped me from sending or recieving emails. Check your options are set correctly. I can login to my bank ok.
Can you please tell us your operating system with service packs and your web browser(s)?
I used the cleaner section. I have tried a system restore to before I used ccleander without help. I use Windows Vista home premium with all the ud to date updates with internet exlporer
Also did you use the cleaner section? or the registry section?
I do use Outlook and I donot have this issue and use ccleaner very regularly
have you tried a system restore to before you used ccleaner?
