Run CCLeaner at startup does not work properly in Win7/Vista. This is due to the required UAC. To get around this search the forum on how to set up a scheduled task for ccleaner which will allow it to bypass UAC
This was touched on in another topic area. I do recall now when I had this problem and UAC was on, it still would not run at startup even though the task scheduler was configured that way. I had to create a shortcut to the task and place that shortcut into the startup folder.
Hmm, I did not disable UAC completely but lower the security slider to the lowest possible mode.
Are there any problems with this situation as well?
Having manually to create a scheduled task and a shortcut and a link is far from being user friendly.
Couldn't this all be automatically created by CCleaner if Win7 is detected?
