New tablet and running CCleaner on it for the first time…it scans then goes to Quick Clean ..Tapped it and on to Finish Cleaning .. Tapped it and it goes back to Quick Clean. I have set all the permissions etc so it is good to go, but it loops. Please advise.
Hi! Sounds like CCleaner is stuck in a loop. Try restarting your tablet and reopening the app. If that doesn’t work, uninstall and reinstall CCleaner. That usually fixes the issue.
