Hi,
I'm about to run this program for the first time, So I was wanting to know what I should check and uncheck in the SYSTEM and ADVANCED section on the cleaner tab?
I don't want to lose anything crucial.
any help would be appreciated.
Thanks
Hi,
Thanks
Hello SupaDawg,
It is fine to have things ticked in SYSTEM, but it would not be advisable to tick anything in advanced unless you are sure what you are doing.
I am having a problem with linking to the beginners guide at the moment, if you post back, hopefully it should be back up .
EDIT: link now working
http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/
Hello SupaDawg,
Ok, Thanks and the link is working now
