CCleaner help
When I click on "Lancer le nettoyage", the same message comes again and again, with slight differences about time (here: 0,196 sec):
NETTOYAGE COMPLET - (0.196 secs)
0,14MB supprim?s.
D?tails des fichiers effac?s
Fichiers Temporaires d'Internet Explorer (fichiers 25) 0,14MB
What does it mean ?
Thanks
Hello,
I couldn't find this report already. Looks like the list of cookies to keep doesn't affect Chrome,
the chosen cookies are preserved for IE only, and always deleted in Chrome.
Cheers
Are you asking what the 0.196secs means?
The time is how long it took to complete the task.
You can keep cookies in IE and Firefox, and I'm sure in Chrome too, although I don't use Chrome.
Close your Chrome browser, you should then be able to see the list, then keep them.
Also there's right-click options on the right side in the 'Cookies to Keep' keep panel. The 'Intelligent Scan' option might be useful.
Where is the option to stop resurrecting a 20-month-old thread with a completely irrelevant posting? Ah, here it is.....
