I recently bought CCleaner Pro as my Cleaner 7 is getting ready to expire.. It deletes itself every time I close my laptop. I hae tried everything and it won’t stop, so I changed from automatic renewal feature. Now it has totally deleted itself instead.and will not reinstall. No return of the fee I paid, though! The programs don’t work and no you are cheating me. This used to be a program I love but now it is a POC and there IS NO ONE TO HELP!
Hi @gailwiesner,
Sorry, you are having an issue with CCleaner.
When you say CCleaner is being deleted when you close your laptop.
Is it that the icon used to launch CCleaner is removed when you close your laptop, or that when you click the icon, you get a message that the app is not available?
Gail Wiesner (Email removed by Admin)
| 6:36 AM (4 minutes ago) | ||
| undefined | -— |
| to Laurence_CCleaner | |
The icon does disappear, but so does the actual program. I have to download it again every time I use it and it always has some glitches. It continually states it is not paid for when it is and I have entered the code. I still have some time on my old subscription (which did work well), and it looks like they are blocking one another. Also, I keep getting messages that it is a “trial” and I will be charged for it, even though I enter the code.
Also,I canceled the automatic renewal feature ONLY and got a message back that the PROGRAM had been cancelled by me.
Could you clarify that for us?
Particularly where you bought the “CCleaner Pro” from.
CClener Pro is not a different application - it is simply CCleaner 7 that has been activated with a licence key to make it CCleaner 7 Pro.
So if your CCleaner 7 Pro subscription was due to expire then it would just renew automatically (Unless you had cancelled the automatic renewal in which case you would have got a renewal reminder email).
