I stupidly ran CCleaner the other day and ran it with the default options. Now when I try and use any of the system related options in Control Panel they either don't work or the screen I get presented with has a few icons on it. but no text and the odd button that appears has no text on it.
I also noticed that when I try and start MS Paint it now reads 'Unable to create new document'
Event Viewer no longer starts
Seems very hosed.
Anyone have any suggestions?
I was going to do a System Restore, but the available points are no longer valid and they fail too.
You need to give more information as just running CCleaner once with default options does not really result in the situation you describe..
What is your operating system?
What build and version of CCleaner do you have?
Did you use the registry cleaning part of CCleaner?
Apologies. I am running 64 bit Windows 7 SP1 and CCleaner Free 5.01.5075 (64-bit)
I did use the registry cleaner, and took a back up. I have reloaded the backup, but still the problem resides. If I right mouse click one of the hard drives on my machine and select properties is crashes explorer.
I have been unable to deduce what else I have done for this to have occurred.
