CCleaner has a back door ,,
2008/03/22,18:43:10 -5:00 GMT,10.0.0.1:2777,10.0.0.138:53,UDP
ASW,2008/03/22,18:50:40 -5:00 GMT
,Win32.Backdoor.Delf.cir,Trojan,
Manual
File Name-C:\Program Files\CCleaner\CCleaner.exe
Article #Trojan | Last updated on 2005-07-14
This program enables a remote user to control your computer. It runs in the background and opens a back door on your computer. The back door allows an unauthorized remote user to connect to and access your computer, circumventing your computer's security. When you connect to the internet, this program notifies the remote user that your computer is vulnerable. This program may also have built-in tools used to manage your files, run executables on your computer, control your mouse and CD tray, screens, and retrieve passwords, keystroke, and screen shots.
How dangerous is it?
Privacy
This program enables a remote user access to your entire computer and everything on it.
Security
This program is a major security threat. The program includes server software that allows a remote user to connect to your computer and have complete access and control over it.
What should I do?
It is recommended that you delete this application immediately because it constitutes security and privacy risks, and has no known usefulness
Look here. Seems as though other people are noticing it.
I have Norton on both of my PC's and it hasn't caught anything. Who knows? False positive most likely.
AJ
All clean at Virus Total.
File CCleaner.exe received on 03.20.2008 18:54:23 (CET)
Current status: finished
Result: 0/32 (0.00%)
Virus Total CCleaner.exe
ZA forum discussion
Manual
Privacy
Security
What should I do?
Hi,
I have the same problem and it still shows that trojan no matter how many times you install or uninstall it. Try the previous version 2.04.543 I installed the previous version then ran the scan and it didn't show anything.
Cheers
I all so test with http://virusscan.jotti.org :rolleyes::rolleyes: & is ok for me may be it got in post-16440-1206651146_thumb.jpgsome how try new download this is the test > PS ver = v200.475
