In Oct there was an issue with cleaner not cleaning all the apps and erroring out. That thankfully was fixed and goes thru fast like before. HOWEVER, mine stops on “settings”and sits there for a few seconds and then skips it and goes on to the next. When it’s done you go back and it hasn’t cleared that one. If you happen to be watching and catch when it stops if you hurry you can scroll down to storage and click there and it will clear. BUT we shouldn’t have to watch and do that. It clears literally everything but settings. Can you please put in a ticket to have that issue fixed as well. I am using a Samsung S25+ and under system info it says Android 16 BAKLAVA model Samsung SM-S936U. Thank you
