Well, that in cleaner free v5.45.6611 can not turn off the monitoring of the system.
I deactivate the monitoring but the process does not turn off, and in the log it is still on at the start as a ccleaner / monitoring or something like that.
For now I go back to version v5.44.6575 that does not have that problem and deactivates the monitoring correctly.
Fix that bug, it’s the first time I have to go back to an old version, and I will not go back to the new one until it works as monitoring should and it really deactivates when you tell it to deactivate, (thing that now in v5.45.6611 not is happening, because it reactivates itself and does not even turn off as homework)
Fix that fault please.
