CCleaner force closes after running
As the title says... CCleaner force closes everytime I run it (the close program setting is not ticked). I think this problem started after the April Patch Tuesday of Microsoft but i'm not entirely sure. The active system monitoring is also affected it also force closes after it runs and or after it detects a browser closing or the limit I've set (5.0gb) on the system wide setting.
Using Windows 8.1 Pro x64. I’m also using the latest version of CCleaner (5.28.6005).
Any ideas on how I can fix this? Thanks a lot.
perhaps it is set to save your settings to an .INI file and things are screwed up somehow.
have you tried uninstalling, rebooting, deleting the CCleaner folder in Program Files (copying your .INI file somewhere if you need/use it) and reinstalling?
Yes I've tried reinstalling and deleting the entire CCleaner folder using a uninstaller software but still the same.
UPDATE
the latest version fixed it for me.
