We have CCleaner on our computers running Windows 7 and Windows XP Home; my wife bought an Android tablet and we are wondering if we can download the free CCleaner software to the Android tablet?
Thanks,
Al Barrs
Thanks,
Al Barrs
Yes there is a ccleaner for android, but you wouldn't install the pc version on the tablet. Instead go to the app store (or open the following link on the tablet: https://play.google.com/store/apps/details?id=com.piriform.ccleaner
On 3/21/2018 at 14:34, Nergal said:<div class="ipsQuote_contents"> <p> Yes there is a ccleaner for android, but you wouldn't install the pc version on the tablet. Instead go to the app store (or open the following link on the tablet: <a href="https://play.google.com/store/apps/details?id=com.piriform.ccleaner" rel="external nofollow">https://play.google.com/store/apps/details?id=com.piriform.ccleaner</a> </p> </div>
Hi Nergal,
I went to the Google Play Store to download CCleaner for my android tablet and also the typed in the weblink you provided but I get an error message. It tells me "Your device isn't compatible with this version". I have a Toshiba Thrive AT100 that's running Android 4.0.4. The part # is PDA01U-00101F. Not sure if that helps or not. I have been with CCleaner for over 10 years and would not like to use another app on this tablet. btw, there are no Android updates for this tablet. Any help is immensely appreciated!
wiseiam
Ccleaner has a minimum system requirement of Android 4.1, thus you cannot use it on your tablet
On 7/22/2018 at 15:13, Nergal said:<div class="ipsQuote_contents"> <p> Ccleaner has a minimum system requirement of Android 4.1, thus you cannot use it on your tablet </p> </div>
oh wow! Thanks for the fast response. I guess my tablet is extremely old and I'll have to find a way to upgrade. Many thanks!
Not a problem
