CCleaner for Android has been updated! Version 1.08 continues to improve the rooting functionality we introduced in v1.07 and adds a reboot option after running a root uninstall.
We've also added the ability to open files from the detail screens, so you can now check the downloaded files that are detected or install APK files that are found!
Change log:
- Improved root uninstall process
- Added reboot option to root uninstall
- Added ability to open files from details screen
- Updated various translations
- Minor GUI improvements
- Minor bug fixes
