ccleaner for android hangs
Hi,
I'm using ccleaner on a nexus 10, android version 5.1.1 (latest versions of all software as far as I know)
Sometimes (maybe once in every 5 runs) ccleaner hangs for me (usually with a message that it's looking for apk files)
I have to abandon that run (after waiting a while), and then the only solution seems to be to power down my tablet and power up again.
Ccleaner then works as expected.
Does this behaviour imply that I'm short of memory (RAM/Disk) and is there some utility I can run to check my android memory (like chkdsk on windows?)
I would appreciate any advice.
Thanks,
Daf
