CCleaner doesn't respect Recycle Bin/24h> setting in (at least) W10
In CCleaner, I have the following:
So I thought “Great! Exactly, what I was looking for.” Yet, when I create a file, remove it, and run CCleaner, the Recycle Bin gets emptied also.
As nobody has seemed to have mentioned this, it's probably a Windows 10 bug(?). I'm on Build 9926.
Thank you for your report. The devs will definitely look in this. As you well know, Windows 10 is an ever changing platform until it is RTM. Being thus, it is piriform's usual position that a pre-release product (alpha, beta testers) is not officially supported until they go Gold. While, I believe, some of Ccleaner's change logs may mention basic Windows 10 support I'd still follow the advice that it most likely will have (major?) issues until Microsoft has released it.
All right. Thanks for looping me in here. :)
