CCleaner do not erase directory $hf_mig$
This directory contain uninstallers of updates in Windows XP
CCleaner will only remove KB updates, this was decided after MrG talked to Microsoft, and thought it would be wise just to remove the KB updates, so it wouldn't cause any OS problems.
I always manualy remove this directory after installing of KB updates, and it don't cause any problems.
This directory always appear after installing Windows XP with integrated KB updates.
I think that it will be better if CCleaner also will erase this directory.
Well ....
Check your system with QFECHECK ... are you always sure you have no pb ?? :o
http://support.microsoft.com/kb/282784
And good reading here : http://support.microsoft.com/kb/824994 concerning $hf_mig$
Well ....
I check my system width QFECHECK, and there are have no problems:
ie7: Current on system.
KB923689: Current on system.
KB929969: Current on system.
KB931768-IE7: Current on system.
Q282784: Current on system.
MSCompPackV1: Current on system.
Wudf01000: Current on system.
KB883667: Current on system.
KB884575: Current on system.
KB885464: Current on system.
KB885836: Current on system.
KB885855: Current on system.
KB887472: Current on system.
KB888239: Current on system.
KB888402: Current on system.
KB889673: Current on system.
KB892559: Current on system.
KB896256: Current on system.
KB901190: Current on system.
KB909095: Current on system.
KB912436: Current on system.
KB915326: Current on system.
KB915865: Current on system.
KB918118: Current on system.
KB920213: Current on system.
KB922819: Current on system.
KB923191: Current on system.
KB923414: Current on system.
KB923694: Current on system.
KB923980: Current on system.
KB924191: Current on system.
KB924270: Current on system.
KB924496: Current on system.
KB924667: Current on system.
KB925902: Current on system.
KB926239: Current on system.
KB926255: Current on system.
KB926436: Current on system.
KB927779: Current on system.
KB927802: Current on system.
KB928255: Current on system.
KB928843: Current on system.
KB929338: Current on system.
KB930178: Current on system.
KB930916: Current on system.
KB931261: Current on system.
KB931784: Current on system.
KB931836: Current on system.
KB932168: Current on system.
I've read all about $hf_mig$ on that page, and I see there is no reasons for saving this directory on my system after installing the updates.
