Ccleaner deletes Start Menu entries
Hello everyone
I have a small problem, Ccleaner deletes the apps from the start menu, I've clicked away everything in the cleaner that pointed to the start menu, but every time I run the cleaner, the apps are gone from the start menu. If I restart the PC they are back. Maybe someone can tell me what could be the reason?
I once made screenshots of the settings in the cleaner
Although I can't be sure I would suspect it's something in those extended entries that you have.
Is that Winapp2.ini? or is it some other 3rd party extension?
Winapp2.ini
I'm not sure if it's the cause of your issue, but I do know that Winapp2.ini is in the process of a makeover/update.
There have been a few glitches reported with the changes.
could you elaborate on what you mean by the apps are gone and they come back?
I also notice you have windows taskbar * enabled, does disabling this fix the issue?
I found the culprit, it is the entry [Internet Explorer *] from the latest Winapp2.ini.
The merged FileKey4 is too aggressive, because it also cleans other cache folders that do not belong to Internet Explorer:
FileKey4=%LocalAppData%\Microsoft\Windows\*Cache*|*|RECURSE
This folder, for example, should not be cleaned up:
%LocalAppData%\Microsoft\Windows\Caches
JFYI: The problem should no longer occur with the latest Winapp2.ini version 230224.
Did find out the causer.
Is this comming from you or a third party provider?
11 hours ago, H6u said:
		<a data-fileid="17242" data-wrappedlink="" href="<fileStore.core_Attachment>/monthly_2023_02/image.png.0b1be56bce5d202b89c61e39cdac56a0.png" title="Enlarge image" data-fileext="png" rel=""><img alt="image.png.0b1be56bce5d202b89c61e39cdac56a0.png" class="ipsImage ipsImage_thumbnailed" data-fileid="17242" data-ratio="28.20" width="266" src="<fileStore.core_Attachment>/monthly_2023_02/image.png.0b1be56bce5d202b89c61e39cdac56a0.png"></a>
Third party provider (you can tell because the *
It depends who you mean when you say "from you".
An asterisk next to an entry means it is not a standard Piriform/CClener entry, it's been added by a 3rd party add-on.
Winapp2.ini is the 'approved' 3rd party add-on.
16 hours ago, H6u said:
		<a data-fileid="17242" href="<fileStore.core_Attachment>/monthly_2023_02/image.png.0b1be56bce5d202b89c61e39cdac56a0.png" title="Enlarge image" data-fileext="png" rel=""><img alt="image.png.0b1be56bce5d202b89c61e39cdac56a0.png" class="ipsImage ipsImage_thumbnailed" data-fileid="17242" data-ratio="28.20" width="266" src="<fileStore.core_Attachment>/monthly_2023_02/image.png.0b1be56bce5d202b89c61e39cdac56a0.png" /></a>
Did you actually read the two posts directly above yours?
