CCleaner "Cookies to Keep"
I have several computers which I use.
In order to be able to use CCleaner frequently, I had to work hard -- on just one computer -- in establishing a list of cookies to keep, so that following cleanup I won't have to introduce myself to my computer all over again.
I'll now have to work just as hard, to establish the same list on the other computers (there are 5 total).
I think that it would be greatly appreciated if there was a way to export the cookie list to a file, and to import such a list from a file.
Two simple ways to do this, use ccleaner portable
or
go to settings > Advaced and choose "save all settings to ini file" you can then copy the file created (in the ccleaner program folder though it may be in the %Appdata% folder for vista/win7) to each machine after setting each instance to save settings in ini file ( i.e hit that switch on each then overwrite the ccleaner.ini with the copied file)
Honestly I'd suggest the first method
The 'Cookies to Keep' only seems to work on IE. I wish I could select which cookies to keep on Firefox. I can get by on things like Remember Password but would still like to select which cookies I want to keep.
No ccokies to keep works explorer, firefox, opera, chrome and flash
