ccleaner closes when minimized to system tray. I tried uninstalling and then re-installing but it still does the same thing. This is new behavior. It used to stay pinned to the system tray at all times.
this happens if you uncheck the option to "show ccleaner in systray". check it and you'll at least have it running in the system tray.
it is one of the many bugs in the new ccleaner...
2 hours ago, jvidal said:<div class="ipsQuote_contents"> <p> this happens if you uncheck the option to "show ccleaner in systray". check it and you'll at least have it running in the system tray. </p> <p> it is one of the many bugs in the new ccleaner... </p> </div>
Hi all! I'm having the same issue. I did not uncheck anything, it just started all by itself. I can not find "show ccleaner in systray" anywhere in CCleaner.
Any help / ideas appreciated.
ccleaner is no longer running reliably without constant attention. I do not have any boxes that say to show ccleaner in the system tray. Clicking the minimize button closes ccleaner.
Same problem in new version ccleaner.
On 29-07-2018 at 19:10, awtj said:<div class="ipsQuote_contents"> <p> Hi all! I'm having the same issue. I did not uncheck anything, it just started all by itself. I can not find "show ccleaner in systray" anywhere in CCleaner. </p> <p> Any help / ideas appreciated. </p> </div>
go to options-->configuration (or settings, mine is in spanish), it's the second checkbox.
I have used CCleaner for several years. All works well until i purchased a package deal of a ccleaner pro last week and defrag and some other app in the bundle (it was only a few dollars more to get the bundle than just ccleaner pro) . So when i installed the bundle that's when ccleaner disappeared from the system tray.
Minimise to tray option is checked but no go.
When i installed the bundle you do have the option not to install specific packages in the bundle..i deselected ccleaner as it was already installed and the other app ..i just wanted defragggler.
Anyway it updated the license detail of ccleaner with the new bundle license and wont stay in the tray.
i uninstalled ccleaner, reinstalled and it picked up the bundle license key and still wont stay in the tray.
Another mystery that i will work on one late night
