CCleaner Version: 2.23.999
Cleaning BUG, I've have unchecked every option:
Internet Explorer
Windows Explorer
System
Advanced
and everything in the application TAB in the aid to resolve this issue although it still occurs.
Basically if I click Analyse and Run Cleaner the application just exit's with no error.
If I just run cleaner without analyse it exit's too.
I have also tried Run As Administrator and the issue still occurs.
PS: I've checked all the other options to see if they resolve the issue etc
also I've looked to see if any other applications are locking files "like apps similar to CCleaner".
Registry Cleaner works without issues, So I can only think this is a code issue?
FIX: UNINSTALL AND REINSTALL RESOLVED ISSUE? I WONDER IF THIS IS A REGISTRY THING? AS I DO HAVE REGISTRY CLEANERS.....
System Spec:
2.4ghz Q6600 Intel Quad
4GB DDR2 Memory
2 x 250GB SATA Hard Drives
Windows Vista Home Premium
