Hi, i'm having problem with CCleaner, everytime i click in "Run Cleaner", the CCleaner close and show in the screen this:"CCleaner found a problem and need be closed"
Help me please, i can't live without this program
PS: Sorry for my bad english!
Do you use secure deletion? If so, try changing it to normal.
I use secure deletion, but now i put in normal, and works!!!
What it's the problem?
PS: Thanks
There is obviously a bug in this version to do with this.
I am sure MrG, the developer, will fix it in the next build.
Welcome to the forum by the way
But it happened with other persons?
Thanks, i liked very of this forum!
Yes
OK, Problem resolved!
Thanks for the fast reply!
I have exactly the same problem. I have Vista and when I run CCleaner 39.502, it simply closes down - whether I run the simple clean, or the 7 times overwrite. I've never had this problem on previous versions, and it really is incredibly frustrating
Let's hope the bug can be resolved, otherwise the CCleaner is pointless - at least on my computer. Great shame!
Just turn off secure deletion in this build.
If you need secure deletion just use the previous build, which you can get from http://www.filehippo.com/download_ccleaner/
