Hi
I have a number of Pinned tabs in my Microsoft Edge - Version 112.0.1722 (64bit)
But Ccleaner seems to clear them out completely when cleaning.
Am I doing something wrong?
Would appreciate some help
Regards
Hi
Regards
Are you using Custom Clean, and do you have 'Session' ticked for Edge Chromium?
If so then unticking it will leave your previous session (open tabs, active logins, etc.) alone and won't clear them, so they should still be there next time you open Edge.
Hi
Thanks for your answer.
I have cleared the "Session" box in both Microsoft Edge and Edge Chromium in the Custom Clean settings.
Hope that solves the problem
Regards
