Why doesn't CCLEANER delete files located in: User\owner\local settings\temp ? I always have to run another clean program.
Possibly the 24 hour rule setting.
You can disable it to see if that's the reason:
1. Open CCleaner.
2. Click: Options -> Advanced
3. Untick/disable: Only delete files in Windows temp folders older than 24 hours.
4. Run CCleaner to see if it will empty your user temp folder.
Yes, The above post contain possible solution of this problem. When i found similar problem then my friend suggest same as above person mentioned here.
