I am new to using CC...and already see what a nice program it is....
I use a screen saver and have it adjusted to a particular size on the monitor. After using CCleaner, (not the reg cleaner) my selected size for the screen saver is lost, and the screen saver goes back to full size on the monitor. The Screen saver program is not listed in CC.
How can I keep CC from altering the screen saver? Thanks...Ponder
Hi Ponder,
You fixed that one situation.
You will have more if you are using the Advanced cleaning options.
Many users turn these on thinking it does a better cleaning job.
These are for certain situations only.Most users don't need these on.
Most result in slower PC operation for awhile.
Unless you absolutely understand the effects of using these I recommend not using them.
You may know this already,I understand.
Many new users do not understand this but that is why the default for these options is off when installed.Don't learn the hard way.
