How may I prevent CCleaner from changing the order of my Links in MS Internet Explorer 7 [View/Toolbars/Links] from my custom sequence, into its alphabetical sequence? I have to manually restore the original sequence each time.
Turn off any Advanced options in the Cleaner.
davey
P.S. I am not sure CCleaner is doing this or not.Normally any problems with resequencing menus and such in CCleaner is caused by using some of the Advanced cleaning options.I am not sure in your case.
Are you also using IE7pro?
