i have CCleaner installed on my computer and i run it regular bases. as of lately the poppup windows that says "CCleaner is now monitoring your computer and will let you know when it needs cleaning" will not go away even when i press "ok thanks" it just says up and continues to poppup
Open CCleaner, then select options...then select monitoring (left hand side)
First untick 'system monitoring' then untick 'active monitoring' (it will popup saying you should leave it enabled however I, and many others, don't have it enabled)
Then click yes to confirm.
do you have the latest version?
I thought, since the new feature was introduced a few versions ago and ON by default, subsequent releases had it OFF by default due to the flawed implementation and user backlash.
