windows 7 sp1 home 32bit
ccleaner pro v5.76.8269
just opening the program on the desktop causes two errors in the wmi event log.
Note - CCleaner debug log removed for users privacy/security - Nukecad.
Does CCleaner run OK for you?
What Antivirus are you using?
Do you have any special firewall settings?
ccleaner runs fine, no errors.
antivirus: Malwarebytes 4.3.0.98 (turning av off same errors).
no special firewall settings.
additional info: wmi event log error message
Apparently that particular error ResultCode in your event log is associated with the operation WbemServices::ExecQuery, which fails with 0x80041032 (WBEM_E_CALL_CANCELLED).
Most Microsoft articles I can find about it only refer to Windows server 2012, that's probably because Win 7 is now EOL.
After some searching I found the following from Microsoft burried in this blog:
http://www.networksteve.com/forum/topic.php/Event_5858_from_WMI-Activity/?TopicId=82067&Posts=1
Scroll down to the post dated April 16th 2013.
Quote<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> The core problem for this set of issues is that the WMI error event ID 5858 <strong>is being generated generically and is not only representing functional error conditions.</strong> <strong>Unfortunately, for application/backwards compatibility, we cant just get rid of it,</strong> because people have gone to the effort of parsing the event (more below) to look for the instances where there is useful data. </p> </div>
Quote<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> ResultCode details: ...... </p> <p> 0x80041032 Call Cancelled. <strong>The client application cancelled the request that was made. That is almost always ignorable as a WMI error.</strong> The component or application (SCCM, or Group Policy) for example) that was calling into WMI cancelled the request, and will likely generate its own event if it is important to do. </p> </div>
In other words Microsoft said/say: "That error is being generated when it shouldn't realy be. - We can't change that without causing other problems. - Just ignore it".
Please note that I have removed the CCleaner debug log from your first post.
The log contained your CCleaner licence key, which I'm sure you don't want to share with the rest of the world.
Final Notes:
Thanks for the link; You are correct. This system is not a server.
Installed version 5.75.8238 same wmi errors
Installed version 5.70.7909 same wmi errors
Installed version 5.68.7820 same wmi errors
Installed version 5.61.7392 same wmi errors
Installed version 5.46.6652 same wmi errors
Installed version 5.44.6575 same wmi errors
After each uninstall no wmi errors.
Installed similar software. No wmi errors.
Final Solution : BYE-BYE CCLEANER!
Your choice of course.
I know you are not using a server, but the MS articles for Win 7 are no longer there.
Because Win 7 is EOL MS have removed any references to it in their 'bug' articles.
But did you not understand that this is a Windows wmi error, not CCleaner?
MS are not going to try and fix it now because Win 7 is EOL.
They are not going to fix it on Server 2012 either - they have told users to ignore it.
Quote<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> <strong>Microsoft said/say:</strong> "That error is being generated when it shouldn't realy be. - We can't change that without causing other problems. - <strong>Just ignore it</strong>". </p> </div>
Hi @mepowers In continuation with what nukecad has said, you may also want to verify if the same event is recorded when using something else that calls upon the WMI service, such as the System Information utility in Windows:
Afterwards, check to see if the same WMI associated event is recorded in the Windows Event Viewer.
