I searched around and couldn't find the answer. Is CCleaner compatible with Vista on a 64 bit machine? I'd like to clean up the useless files but I think CCleaner does a much better job. Thanks for your help.
Never mind, I found the answer. and for others...CCleaner can be used in Vista 64 bit. Thanks for the help.
Yes you are right a12iggymom, it can be used.
A bit more info here
http://docs.piriform.com/ccleaner/introduc...em-requirements
and it works great, been using it on my system for a year now.
