Under Windows Vista the UAC was introduced and to prevent older programs, not running as admin, which want to access their folder under Program Files, to crash because of missing privileges, Microsoft introduced the VirtualStore. This folder can be found on the file system and in the registry.
I don't have those locations on my XP system so can't check myself, and I can't see them in CCleaners winapp.ini file, which are the locations hot wired into CCleaner.
They may be in the user generated "winapp2.ini" file, but I don't use it and it isn't an official Piriform supported item but one of the guys who does use it may contribute.
You could always make sure those locations are cleaned by adding a manual "Include" for them ...
Can't copy must be placed there by the os for the link to be made, that folder is for "badboy" programs that don't follow Microsoft's no user changeable in program folder without uac elevation
So I can't just copy it. How to test it then?
Edit: I know now. I have one of these "badboy" prgrams and I will just write a rule for CCleaner which deletes the programs files.
Install a program that uses it and that ccleaner cleans. It sounds like you're working on theory instead of with a practical example, find one then we'll know
So I did this: VJoy is the program which wants to write to C:\Program Files (x86)\VJoy\VJoy.ini and this file is in C:\Users\username\AppData\Local\VirtualStore\Program Files (x86)\VJoy. I guess because I don't run it as admin. So I made the following rule:
As I'm doing my taxes, I'm on my pc. I took a break and yes this does not function as I was hoping, perhaps there is a way for it to work but I know not
