Just wondering if Ccleaner should be detecting Tixati in 'applications'?
I am running Windows 8 64bit
This is not a bug report, but a suggestion (wrong forum area). Which CCleaner version are you using?
Winapp2.ini has this entry for Tixati:
[Tixati Logs*] LangSecRef=3021 DetectFile=%AppData%\tixati\upnp_diagnostic_log.txt Default=False FileKey1=%AppData%\tixati|upnp_diagnostic_log.txt
thread moved
I am using Version 4 (the latest version).
Have you downloaded the Winapp2.ini file and retested ?
Are you aware of Winapp2.ini and how to use it - if not then see :-
Never heard of winapp2 - Looks like I will need to download it.
Thanks to all that have replied.
