1: Are you sure the tick box next to Temporary internet files is ticked?
2:If yes to 1 then try adding the folder to "Custom Folders" in "Options" and see if that works.
3:If you have done both 1 & 2 then I have not got a clue. Maybe CCleaner is removing the files but windows is recreating them so when you browse to the folder it looks like CCleaner has not removed them.
Marked for deletion: C:\Documents and Settings\TwistedMetal\Local Settings\Temporary Internet Files\Content.IE5\index.dat
Marked for deletion: C:\Documents and Settings\TwistedMetal\Cookies\index.dat
Marked for deletion: C:\Documents and Settings\TwistedMetal\Local Settings\History\History.IE5\index.dat
Marked for deletion means you must restart your computer in order for the index.dat to be deleted. Once you run IE the index's.dat are recreated. I hope this answers your question.
i know that windows recreating the index.dat file of 32kb,
but unfortunately the file is the same also after reboot and the content is visible using a tool f.e. index.dat viewer, so the file is neither cleaned nor deleted
i didn't want to be rude, i just wanted to emphasize the i know that CCleaner mark for deletion that files, and i know that you all try to help me and for that i thank you.
