CCleaner and NWN2
With default settings selected CC v2.00 reports alot of Neverwinter Nights 2 resources as junk, so maybe there should be an exception for this or something. Yes I am aware that I could exclude this and yatta yatta, Im not a newbie, Ijust wanted to report this so other, hasty, users don't get their nwn2 saves deleted.
Anyways, thanks for the program, and Im sorry if anyone already reported this, or if this post breaks any rules, la la ;). (dont really have time to get to know the rules of yet another forum ;))
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-ammon_jerro.ros 0,13MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-bishop.ros 0,12MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-casavir.ros 82,52KB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-construct.ros 78,63KB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-grobnar.ros 0,12MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-khelgar.ros 0,33MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-neeshka.ros 0,17MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-qara.ros 85,79KB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-sand.ros 0,40MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-shandra.ros 0,11MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-zhjaeve.ros 0,13MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROS-npc_bevil.ros 49,98KB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\screen.jpg 15,27KB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\playerinfo.bin 170 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN_Tutorial.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\ROSTER.rst 4,46KB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\player.bic 0,26MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\savenfo.txt 23 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\playerlist.ifo 0,30MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN_Tutorial.Z 1,49MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1100_West_Harbor.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1100_West_Harbor.Z 3,08MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\globals.xml 0,17MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\currentmodule.txt 22 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1200_Highcliff.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1200_Highcliff.Z 6,83MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1000_Neverwinter_A1.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1000_Neverwinter_A1.Z 6,10MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1700_Merchant_Quarter.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1700_Merchant_Quarter.Z 5,99MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1900_Slums.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1900_Slums.Z 1,17MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1800_Skymirror.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1800_Skymirror.Z 0,25MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1300_Old_Owl_Well.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1300_Old_Owl_Well.Z 4,15MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1600_Githyanki_Caves.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\1600_Githyanki_Caves.Z 3,94MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2000_Neverwinter.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2000_Neverwinter.Z 7,82MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2200_Port_Llast.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2200_Port_Llast.Z 2,72MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2300_Crossroad_Keep_Adv.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2300_Crossroad_Keep_Adv.Z 1,42MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2100_Crossroad_Keep_A2.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2100_Crossroad_Keep_A2.Z 14,9MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2400_Illefarn_Ruins.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2400_Illefarn_Ruins.Z 3,20MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2600_AJ_Haven.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\2600_AJ_Haven.Z 1,50MB
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\3000_Neverwinter_A3.sav 3 bytes
C:\Documents and Settings\G3n7r0\Local Settings\Temp\NWN2\CURRENTCAMPAIGN\3000_Neverwinter_A3.Z 6,41MB
Even cc 1.4 should have deleted thease cause the are located in a default windows "temp" directory.
My guess is they should be safe to delete, as save games should be either located in the games install directory,
or in a My Documents sub folder.
yup, you're right, I overlooked the 'Temp' part.
My bad.
